Failed to creat system from back up
huihai
I want to creat system from back up ,but failed.
The prompt is as follows:
Have but few friends, though many acquaintances.
Hi, the message says every thing. You are trying to make a system from Backup, but this backups uses a addtional Option, that you don't have in your mediapool folder (Mediapool forlder is the folder where RS store the RobotWare and addtional options).
You must get a copy of the additional option. Usefull you can find it on the robot where you get the Backup. Search for a folder into de HD0a called 3HNA01783-001, and get a copy of folder.
Then import it using "Import options, on Online tab.
/Jorge
Jorge Turiel0 -
The problem is solved with your help,very grateful!I work as a paint robot engineer in an auto company since I graduate from university last year. I found the work is meaningful but hard to learn at the same time.After few months,I have learned something simple about maintence . But what I really want to learn is about programming,reference materials are limited, only robot manual is available.Thanks to the internet,I found the useful information.Robot Studio,which I think will be helpful,but I do not know how to use it , free tutorials are very useful but too little to help.SO I wonder if I could get any help from you.Thank you very much!Have but few friends, though many acquaintances.0
- 85 OmniCore
- 37 AppStudio
