robot shake when motor off
ssu_8421
I have a 7600 robot. Sometime it will shake for many times (about 6 times) when i use fine move to make it move to a positon(in auto mode) and send the "motor off" command from PLC. Is there anybody know why and how to solve it. Do i need to adjust the parameter of motion/brake?
the load is about 200kg0
Hi,Have you done a loadID on the tool?0
- 858 RAPID Programming
