How to build a sinusoidal trajectory
Hatem
Dear friends,
I hope I can get solution for this issue with youI want the robot to perform a sinusoidal trajectory where
the series of points positions and velocities (and accelerations if possible )are
defined by the following equations with sampling time (t) for a particular
period of time (T):
Oc(t)= sin(2I_t/T)
velocity(t)=(2*pi/T)cos(2*pi*t/T)
acceleration(t) = - (4 pi^2/T^2) sin (2*pi*t/T)
I understand that the robot movements for its end-effector
or joints is performed through motion commands such as MoveL, MoveJ, etc. So
how to convert the given trajectory into a set of robot motion commands so that
the trajectory is smooth with time.
Would you kindly help me to know how to get this done.
Thanking you in advance.
