Simulation Speed problem
Here's my problem, I set up a simulation in robot studio and everything ran fine. Now my simulation has suddenly slowed to a crawl, I know it is not the simulation speed setting in the options menu, as everything is set to default, I know it is not the velocity settings on the programmed points, as all are set to higher values 1000, etc. The timer runs at full speed and is showing no lag, so therefore, my simulation shows the same moves that were once done in 12 sec time in about 500 sec.(yea, it crawls). There is no sign of lag when I'm creating new points/jogging robots/usual interactions, just when simulation plays. Does anybody have any suggestions as to when I could do? I have had the IRC5 programming and electrical service courses, but am not so great with internal screens of robot studio so any steps would be greatly appreciated.
  • Hi,
    Open up the FlexPendant and check so the speed is not reduced there. Sometimes I have seen that  the speed has been reduced by itself to 5% here.
    ABB Robotics
  • Thanks a lot!!!!
    Exactly this had happened to me also. I've searched for a fault in my simulation all morning.... My flexpendant showed 3%
    Janette
  • I'm having the same issue. My teaching pendant shows like "Running (Speed 3%)". How can I increase it?
  • In the Quickset menu in the Virtual FlexPendant, or just change operating mode to Auto.
    Johannes Weiman
    Software Engineer
    RobotStudio Team, ABB Robotics
