S4 robots on RobotStudio 5.14.03 ?
Dear all,
I'd like to know, if it would be possible to create a station with old S4 robots on RobotStudio 5.14.03?
Thanks for answering,
Luxrobotic2012-07-17 11:40:56
Regards
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
http://www.luxrobotic.com
HP ZBook Fury 16 G11
  • Hi,
    You can only use IRC5 systems (Virtual Controllers) in RobotStudio 5.xx.
    But I know that some people who has S4 robots use RobotStudio 5.xx anyway. If the robot model you should use also have been sold with IRC5 controller (e.g. IRB4400), you can setup an IRC5 system for your robot. The RAPID language is the same in S4 and IRC5 (except for some process instructions that have been changed in IRC5), so if you convert the I/O-file (EIO.cfg) to IRC5, you can use RobotStudio 5.xx to program your S4 robot, but only if the robot model exist in RobotStudio 5.xx.
    ABB Robotics
  • Hello,
    thank you for your reply,
    I'll try when I will have some avaibility.
    Regards
    Cornet Raymond
    Manager
    +352 621 354 570
