Transparancy of selected target names
I do a lot of freehanding targets in RS. The problem is that I have to change a lot of my display settings so I can tell which target is highlighted. Select the target under the Workobject then freehand that target. It is still highlighted but is so very light I often have to guess which target I was working with. Luckily I have two monitors that I can use with different settings. It seems that the highlighting was darker in the 5.10 5.11 days.
