Write protected RS project file
Hi Support!
Hope you can help me with this tricky problem!
I have created at pack and go file in Robot Studio school edition 5.13 that our students have used without problems last year.
Every time they have unpacked it in Robot studio default directory, overwriting the existing project. Thats perfectly ok.
Now when i have installed RS 5.14.02 and trying to unpack it to RS default directory, i got the following message.
"one or more read only files exist in the target location. please select a different directory"
I have notice that  psc_irobot_1.sxml becomes write protected. When i change it's file attribute in windows it works fine one time. Next time i unpack the pack and go file RS change it to write-protected again. Why?.
Extra info! I log in as administrator and i have tried to make a new pack and go file with 5.14.02 without success.
Best regards... Per-Erik
  • Is your rspag or rsstn files resides on a network drive?
    I have experienced some read only issue with Win7 and 5.14.03, while my station or pack&go files where not on a local computer.
    Running RobotStudio.exe as an administrator solved the issue.
    - Francois
