Editing a Semistatic Task
TommyT
How can you edit a Semistatic task in RobotStudio or using text editor?
If you can edit the task then how do you reload the task?
Tommy Thompson - Propack
Hi Tommy,
To edit a background task change the Task Type to Normal.
You don't have to reload the task if you have edit it in RobotStudio Online or with the FlexPendant. If you have modules that are automaticly loaded, you have to perform a P-start. To perform a P-start select Restart and then Advanced, there will you find P-start.
ABB Robotics0
- 40 AppStudio
