simulated IO
Rookie
I am trying to find a way to reset simulated signals in rapid. Does anybody knows if this is possible?
thanks.
thanks.
Did you tried the "Reset DO_1;" (DO_1 is the Digi Output signal)?I`m using it and it works.Regards Szily0
SetDO doSim,0; normally works also.0
