Test if PROC is defined
Laro88
I have a case where I would like to execute a PROC if it is defined.
My case is that I upload a RAPID program, and if the program has a special PROC defined, then I would like to execute it...
Basically in pseudocode
IF (defined(nn)=true) THEN
EXEC nn;
ENDIF
Is this possible in RAPID?
EXEC nn;
ENDIF
Hello,Yes, you should be able to do this. One suggestion is by first searching for the Proc symbol (see SetDataSeach and GetNextSym instructions) to find the Proc name, and then use "late binding" to execute the proceedure (put the Proc Name into a string and then call the string as a proc with %stringname%)You could also skip the symbol searching and simply call the procedure using late binding, if the procedure exists, it will be called, otherwise an error will occur and you can handle the error automatically in the error handler of the procedure.Steve0
Ok, thanks for the suggestions - I will try it out soon.
Too bad there is not "PROC_isDeFined(String_ProcName)" method hidden somewhere
Steve_Murphy said:Hello,Yes, you should be able to do this. One suggestion is by first searching for the Proc symbol (see SetDataSeach and GetNextSym instructions) to find the Proc name,I'm trying to do exactly this, but I can't figure out how to do it.How can you search PROC names with SetDataSearch?For example if i'm trying to find all PROCs that begin with a word Process. What should I use as SetDataSearch Type argument?SetDataSearch "??????"\Object:="Process*";WHILE GetNextSym(name,block \Recursive) DOTPWrite("found: " + name);ENDWHILE0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 34 AppStudio
