DSQC 652 problem in compact controller
bmrgud
Hello to all. Could you please inform me how to supply voltage to DSQC 652 in compact controller, and is it necessary to make some other connections besides bringing 24V DC to I/O card. It is newer controller with XS10 connector instead of SX6.
Thanks in advance.
p.s. is i possible to order I/O outside cable instead of soldering our own for XS7 connector.
Thanks in advance.
Hello,The supply voltage of DSCQC652 in IRC5C can be provided at XS10 as follow drawing
If XS10 was installed an terminial, the IRC5C internal provide the voltage.
Otherwise you will have to provide 24VDC at Pin 3,4 at XS10
Yes , You can order I/O external cable instead of soldering our own for XS7 connector
The order option is 731-5
ABB will install an connection bar which have an cable connected at XS7,Kind Regards,
Steve1
