Help and errors
Hello!
I get this error when i try to open a station file:
RobotStudio .NET exception: Parent is dead
Base exception: InvalidOperationException
Parent is dead
   at RobotStudio.API.Core.CmList`1.Backup()
   at RobotStudio.API.Core.CmList`1.Insert(Int32 index, T item)
   at RobotStudio.API.Internal.AssemblyModeler.ReplaceComponent(GraphicComponent instance, GraphicComponent srcInstance)
   at RobotStudio.API.Internal.AssemblyModeler.ReplaceModifiedLibrariesRec(GraphicComponent instance)
   at RobotStudio.API.Internal.AssemblyModeler.ReplaceModifiedLibraries(AssemblyRoot assemblyRoot)
   at ABB.Robotics.RobotStudio.Stations.Station.Load(String fileName, Boolean asReadOnly, ProgressNotification progressDelegate, FileNotFoundNotification fileNotFoundDelegate, Boolean loadGeometry)
   at ABBInternal.FileCommands.FileCommandServices.OpenStation(String fileName, Boolean loadGeometry)
   at ABBInternal.FileCommands.OpenStationCommandHandler.OpenStationCommandHandler_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
   at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand(ExecuteCommandReason reason)
Also, lately when i open a station file, multiple instances of a smartcomponent is added and attached to each compontent i all other smart components.
VictorL2012-09-04 09:06:18
  • Please get in touch with your local ABB Robotics Service representative that can foward your issue to our tech support, see http://www.abb.com/contacs. For schools there is one dedicated contact per school that can forward your issue to our tech support. If you are placed in Sweden, you can contact RobotSupport directly, see http://www.abb.com/product/ap/seitp327/d4fc82d62e864f20c125762e004cd845.aspx (it looked like there were some swedish object names in your station).
    Please supply .rspag file (if available) and error logs (full scan).
    Before contacting support, ensure that you are running RobotStudio 5.14.03.
    ABB
