Border Creation
rick
While creating borders to be used as weld paths between a complex part and a simple cylinder the error objects are disjoint appears. I know that the objects intersect so it isn't obvious what is the problem. What else could this mean? There is no information in the help menu. I can go around this problem but it has been a nuisance. What's going on?
Rick Frederickson
Mechanical Design Engineer
Integrated Robotics
40 Old Dover Road
Newington, NH 03801
Ph: 603-766-3491
Fax: 603-766-3485
Integrated Robotics
40 Old Dover Road
Newington, NH 03801
Ph: 603-766-3491
Fax: 603-766-3485
Hi Rick,
To find out why the function "Create Border - Intersection" doesn't work for you, I need access to the CAD-model you had problem with.
You can mail the CAD-model to my e-mail: anders.spaak@se.abb.com
ABB Robotics0
