LoadModuleFromFile return error
I try to load a module to robot and
get an error<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
First I put a the file to robot file
system at HOME :
GetABBRobot().FileSystem.PutFile("C:/TEMP/OPTITILE_PATH.mod",
"OPTITILE_PATH.mod", true);
Then I try to load it to robot using
bool
loadResult = task.LoadModuleFromFile("C:/Avi/Offline/Ecm/Abb/BMW3/bmw4/HOME/OPTITILE_PATH.mod",
ABB.Robotics.Controllers.RapidDomain.RapidLoadMode.Replace);
and get false at loadResult,
when I am working with real robot
if I run the same code
using simulator its work ok
Any one can help ?
thanks Avi
Hi Avi,After copying file to robot can you load that module directly from robot's home directory?bool loadResult = task.LoadModuleFromFile("HOME:/OPTITILE_PATH.mod",ABB.Robotics.Controllers.RapidDomain.RapidLoadModule.Replace);BR.charon2012-09-13 15:14:39Erdem Karaçeper0
i tried it same problem,What i find out that the function return false but the module was load in the robot ?0 -
Hii avicohen,Remember to write out which SDK you are using. This so that users only interested in one SDK doesn't have to read about all the other ones.
As Charon pointed out, your problem is that you are using a path to the C: drive and there is no C: drive on the controller, its root paths usually start with hd0a. Why that works on the VC is because it resides on a PC.
This is why if you use both virtual and real controllers its better to use relative environment handles. For instance look how it is handled in the Backup and Restore chapter.
By using the "string backupDir = "(BACKUP)$" + backupDirName;" line you would get different paths if its virtual or real, but it would both be pointing to the Backup folder on the controller. Same thing with HOME as per the File System Domain topic.
John
Developer Center0 -
Hi John,<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Thanks for the support.
I am working with PC SDK 5.14
What I am doing is : GetABBRobot().FileSystem.RemoteDirectory;
For that string I add
: + "/" + modulename;For real robot the
directory is : /hd0a/66-70153_limpio/HOMEAnd for that path I try
to do LoadModuleFromFileWhat I find out that
the module is loaded to robot, if the module contain new procedure I can see
them on the robotBut the bool the the
function return is "false" and I don?_Tt understand why ?I tried to something
like LoadModuleFromFile("HOME:/" + modulename,
ABB.Robotics.Controllers.RapidDomain.RapidLoadMode.Replace);And get the same
results, (module was loaded but the function return error)Do you know something
about it ?Regards
Avi
- 364 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 33 AppStudio
