how to set up a system of spot servo gun
i create a system with a servo gun.
1a__import a 6620 robot ,import a servo gun, attach gun to robot.
2a__create system from layout, use virtual key,chose option spot servo equalize, add drive like below.
r/??1?>r??+?/??Y?"??."???o_?z?/??Y?"??."???o_?z?/R4/Backup_20070225/system.xml#" target="_blank">- <Option descr="Add axes IRB/drive module 6600/660">
r/??1?>r??+?/??Y?"??."???o_?z?/??Y?"??."???o_?z?/R4/Backup_20070225/system.xml#" target="_blank">- <SubOption descr="770-4 Drive W in pos Y2">
<SubOption descr="No drive in pos X2" />
33a__when vc started ok, i find i can't use the instrution actunit to active the servo gun. but i can "use mechanism joint jog" to jog the servo gun.
3
Tom And Jerry
You need to add the RobotWare option for Spot welding to your controller system.Henrik Berlin
ABB0 -
Hi Henrik Berlin,Thanks for Sharing Knowledge,i had a Doubt please clarify it.in case i had a tool changer and i am using 2 spot welding guns with different TCP; How to Define themand how to use them in programming0
