RobotStudio crashing
bme
RobotStudio crashes quite often, and yes, I am using the newest version. There are many bugs that are extremely annoying, but the worst bug that exists in all the newer versions of RobotStudio, including the current one, should have been fixed by now. It seems that if RobotStudio crashes, the RAPID programs are saved at all, that is, even though I have been saving the project many times, the changes made to the RAPID programs are almost magically reverted. The only solution to this is to manually save the RAPID programs as well when working with RobotStudio. I don't understand why you have not fixed this bug yet.
Another, very strange bug occurs when working with the geometry in RobotStudio. Quite often geometry appears to be lost, that is, it can no longer be selected, moved around, deleted and so on. This always happens when importing a big step file with many parts. After a while, parts starts getting lost, and it is no way of getting it back. I then have to delete all the geometry and import it anew. This bug has existed in all the versions of RobotStudio that I have been using.
I really hope these bugs will be fixed in the next release of RobotStudio.
- 40 AppStudio
