offset help
can someone please help, and let me start by saying im very new to robots and programming of them.
PROC Recovery()
!wrote by gareth thwaite to
aid recovery
! set slow speed for recovery
CONST speeddata
GarethSpeed:=[500,500,500,500];
!+++++++++++ var position for
recovery++++++++++++++
VAR robtarget recovery1;
CONST robtarget
pabovetray:=[[349.48,-934.95,854.23],[0.0237752,0.716986,0.695494,0.0406639],[-1,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget
phalfhome:=[[391.49,-337.97,854.23],[0.023777,0.716985,0.695495,0.0406651],[-1,0,0,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
WaitTime 0.8;
recovery1:=
crobt( ool:=tool0WObj:=wobj0);
MoveL
reltool,(recovery1,0,0,-300),GarethSpeed,fine,tool0WObj:=wobj0;
MoveJ
pabovetray,garethspeed,fine,tool0;
MoveJ
phalfhome,garethspeed,fine,tool0;
MoveJ pHome, vCycle,
fine, tool0WObj:=wobj0;
waittime 5;
main;
ENDMODULE
the porblem is i dont know the command to move it with an offset relative to the world/robot rather than the tool,
can anyone help?
Gareth_Minting2012-10-05 15:26:37
Hello,Given that you have the recovery1 point, and it is already in the world/base frame of the robot, I would suggest that you skip the reltool and simply modify the Z value of the point itself,recovery1.trans.z := recovery1.trans.z + 300;MoveL recover1, GarethSpeed,fine,tool+Wobj:=wobj0;RelTool is for use when you want to extract a tool in the direction of the tool z (or x, y).Steve0
thanks steve, i just did it anyother waymove L offs(recovery1,0,0,300),garethspeed,fine,tool0;thanks for the reply,0
