variables not defined
esxamar
I need crate a instruction in a mainmodule with a variable not defined.
For example; reg1:= AAAA ;
The variable AAA is defined in a module that i want load later with the instrucion StartLoad.
Now when I load the mainmodule with the instruction re1:=AAA; i have a syntax error.
Is possible to add any argument to avoid the syntax error and execute the programa normally,
Thanks
Thanks
You can use the system parameter "Bindref". This will help you out.0
- 364 IRC5
- 82 OmniCore
- 853 RAPID Programming
- 35 AppStudio
