automatic tool search
I'm still a beginner with Abb and robotstudio.
I want my programm to search automatically for new tooldata. The new tools must be written in a commandbox so that the user only has to click on the correct one to use it.
Unfortunately I have no idea how to make it work.
I hope one of you has an idea.
Tami
  • Hello,
    I believe you are trying to create an application targeting the FlexPendant:
    Using ScreenMaker - All tooldata names could be stored in an Rapid array and can be bound to a control like combo box. On change in combox box selected index, read the value of tool data and display it a control like label, etc.
    The solution above is more like you are reading from a rapid array. It will not find any new tooldata that is made available.
    To find new tooldata, you can write a .NET method which finds new tooldata and updates the rapid array.
    Thanks
  • Thats my code:
    Var datapos block;
    Var string name;
    Var tooldata infos;
    Pers num zaehler;
    Pers string Werkzeugnamen {10};
    Pers string Werkzeugdaten {10};
    Proc Werkzeuge()
    Zaehler := 0;
    SetDataSearch "tooldata" Object := "t.*" InMod := "Hauptmodul";
    WHILE GetNextSym (name,block) DO
    Zaehler := Zaehler + 1;
    GetDataVal namelock :=block, infos;
    Werkzeugnamen {zaehler} := name;
    Werkzeugdaten {zaehler} := infos;
    ENDWHILE
    I link the array to the Combobox. Works great even if i am still annoyed that there isn`t a dymatic array like in info.
