RobotStudio SDK 5.15 Release
What?_Ts New
This is a short version of the content in the What's New PDF document which you can find here
RobotApps?,? integrated in Document Window
Content published on the RobotApps web site under http://www.abb.com/roboticssoftware can now be accessed inside RobotStudio.
RobotStudio 64-bit edition
RobotStudio is now available in a 64-bit version.
Support for asynchronous programming
The RobotStudio API now supports asynchronous programming by returning Task<> from some methods.
Online and Offline tabs merged
In RobotStudio 5.15 the Offline and Online tabs have been merged into the Controller tab.
More APIs for working with Station controllers, virtual controllers and real controllers
Launching the RAPID Editor and Configuration Editor
Applications can lunch the RAPID Editor or the Configuration Editor, given the URL to the RAPID module, or configuration domain.
Denavit- Hartenberg parameters for mechanisms
The new method DenavitHartenbergParameters[] GetDenavitHartenbergParameters() can be used to retrieve DH-parameters for the specified mechanism.
And there is more Smile. Read if you cant get enough continue to the What's New PDF document. It has a complete list of all new methods and new types in the API.
Or browse the reference documentation at http://developercenter.robotstudio.com.
Best Regards, Niklas Skoglund
ABB Robotics
Developer Center
RobotStudio Blog
