FlexPendant SDK 5.15 Release
Niklas Skoglund
What?_Ts New
FlexPendant on Developer Center
You can now access the FlexPendant Application and Reference Manual from http://developercenter.robotstudio.com.
To help you get started you will also find complete walk-through projects for download.
Known limitation
Visual Studio 2008 cannot attach to VirtualFlexPendant.exe 5.15
VirtualFlexPendant.exe distributed with RobotStudio 5.15 and later is built with .NET
4.0. VisualStudio 2008 is not able attach and debug a .NET 4.0 application.
Hence it is not possible to use RobotStudio and the Virtual FlexPendant to debug a
FlexPendant SDK application from Visual Studio 2008.
Workaround #1: Visual Studio 2010 or Visual Studio 2012 can be used for attaching
and debugging VirtualFlexPendant.exe. You can open a code file from your Visual
Studio 2008 project, from Visual Studio 2010 and set breakpoints. The debugger will hit
the breakpoints and you can execute step vice etc.
Workaround #2: Do not uninstall RobotStudio 5.14.03 when installing RobotStudio
5.15.Visual Studio 2008 can attach to and debug the VirtualFlexPendant.exe 5.14.03.
Several fixes to problems with FlexPendant controls visual appearance has been made. The complete list can be found in the Release Notes.
John Wiberg2013-02-06 13:02:13
