Add-In DLL File Not Loading with RS?
Lin
Hi All,
When you download Add-In from the forum.
Some DLL's are not working and Shows error in the Output Window when you try to load Add-In.
To avoid this error, after downloading the Add-In DLL from the forum.
Right Click the DLL --> Properties --> Unblock --> Apply.
Then place into the Add-In directory, the it will work.
Lingaa
