Romaning Desktop
Can the new robotstudio 5.15 run on a roaming desktop ?
\serveruser....Robotstudio
i get this error:
RobotStudio
.NET exception: A Task's exception(s) were not observed either by Waiting on
the Task or accessing its Exception property. As a result, the unobserved
exception was rethrown by the finalizer thread.
Base
exception: AggregateException
A
Task's exception(s) were not observed either by Waiting on the Task or
accessing its Exception property. As a result, the unobserved exception was
Inner
One
or more errors occurred.
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean
includeTaskCanceledExceptions)
at System.Threading.Tasks.Task`1.get_Result()
at
RobotStudio.Services.RobApi.Retained.RobRetainedNetscan.<>c__DisplayClass2.<Init>b__1(Task`1
t)
at
System.Threading.Tasks.Task`1.<>c__DisplayClass17.<ContinueWith>b__16(Object
obj)
at System.Threading.Tasks.Task.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
Inner
exception: TypeInitializationException
The
type initializer for 'RobotStudio.Services.RobApi.NetscanInternal' threw an
exception.
at RobotStudio.Services.RobApi.NetscanInternal.get_RobNetScan()
at RobotStudio.Services.RobApi.RobNetscan.GetControllerNetscanIdsInternal()
at RobotStudio.Services.RobApi.RobNetscan.<>c__DisplayClass5.<GetAllControllersAsync>b__2()
at System.Threading.Tasks.Task`1.InvokeFuture(Object futureAsObj)
Inner
exception: InvalidCastException
Unable
to cast COM object of type 'RobotStudio.Services.RobApi.RobNetScanHostClass' to
interface type 'RobotStudio.Services.RobApi.IRobNetScan'. This operation failed
because the QueryInterface call on the COM component for the interface with IID
'{E4BD1362-2395-447F-911F-0AC363E1E047}' failed due to the following error: No
such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at RobotStudio.Services.RobApi.NetscanInternal..cctor()
Thomas G Andersen
DanRob A/S
