Virtual FlexPendant Explorer startup problem
Im getting an error when opening the FlexPendant Explorer on a virtual FP... this is happening on RS 5.15 with any virtual system running on all versions RW.
I get an Error message stating 'Flexpendant Startup problem' when accessing the FP Explorer.
Thanks in advance
FYI: Windows 7 32bit
  • What result do you get with the FlexPendant of RobotStudio 5.14.03?
    ABB
  • On my old WinXP PC with RS5.14.03.01, flexPendant Explorer works fine...
    But any virtual systems running in RS5.15 on my new Win7 PC fails to open the FlexPendant Explorer, I have tested the VC with both RW5.15 and RW5.14.03.
    Even default RW5.15 virtual controllers fail to open the FlexPendant Explorer
    Kind regards
  • My guess is that the problem is due to some security configuration of your computer environment possibly in relation to .NET Framework. (The Virtual FlexPendant of RobotStudio 5.15 uses a later version of the .NET Framework than that of 5.14.03.)
    Where do you store the systems? Is it perhaps on a location to which the FlexPendant does not have access? Is it on a network drive? The FlexPendant Explorer defaults to the HOME folder of the system. Maybe there is a relation?
    ABB
  • Hi
    You are right... Studio installed the Stations and Systems folder to C:UsersgbsiturDocumentsRobotStudio folder. The gbsitur folder has a padlock symbol and I guess is security enalbled...
    I created a new system on the root of C drive and the FP Explore will open... I will pack and Go all stations / systems to another folder.Thumbs Up
    Many thanks
