Editor not working over ethernet?
Hallo!
I got the following problem:
I open RS 5.15 and connect to a controller over ethernet.
Then I try to open a Rapid-Module by double-klicking on it.
The Editor will not open. I get the following message in the output-tab:
"RAPID-Editor: Unknown error (0XC0040FFE)"
It will work when the controller is connected over the service-port.
With RS 5.14 it works both ways.
Is this intended behavior of the new version or a bug?
Regards
Michael
  • Hi Michael,
    I would recommend you to get in touch with ABB that can forward your issue to our tech support. Please get in touch with you ABB Robotics Service contact (see www.abb.com/contacts).
    ABB
  • Hallo!
    I've contacted ABB Germany in Friedberg.
    Together we figured out, that it only depends on the RobotWare-Version.
    With RW 5.06 it's not working. Higher Versions are OK.
    (Seems I tested it always on the same controller...Embarrassed)
    I was told, that with 5.06 it should not work with RS 5.14 either.
    But it works. I've sent a screenshot to proof it. Now they will check
    why this works.
    We only have 3 controllers with 5.06., so it's not a big problem.
    Thanks
    Michael Kobbeloer
