Internal Errors " ItmSrcCnv1: Failed to execute...
does
someone knows something about the following internal errors?
I already
spoke to the german ABB Personal and he contacts the Swedish guys. I will get
some information from them, but i just try to get some faster hints.
Any Ideas
whats going wrong there?
RW5.14.03 and RW5.15.
[QUOTE]
2984 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
ppadat.c 205
Unable to get memory allocation for size: 0!!! {args: "ppadat.c 205
Unable to get memory allocation for size: 0!!!"}
2985 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
ppadat.c 205
2986 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
ppadat.c 205
2987 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
itmsrcpr.c 1328
ItmSrcCnv1: Unable to alloc memory for reading enc config, left: 2053180 bytes,
-19 {args: "itmsrcpr.c 1328 ItmSrcCnv1: Unable to alloc
memory for reading enc config, left: 2053180 bytes, -19"}
2988 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
itmsrcpr.c 1145
ItmSrcCnv1: Failed to execute method itmsrcpr_read_encboard_config,
-19
{args: "itmsrcpr.c 1145 ItmSrcCnv1: Failed to execute method
itmsrcpr_read_encboard_config, -19"}
2989 E
Interne
100000 Interner
Fehler
2012-11-12 15:37:25
itmsrcpr.c 3942
ItmSrcCnv1: Failed to execute method itmsrcpr_cnv_data,
-19 {args:
"itmsrcpr.c 3942 ItmSrcCnv1: Failed to execute method itmsrcpr_cnv_data,
-19"}
3001 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
ppadat.c 205
3002 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
ppadat.c 205
3003 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
ppadat.c 205
3004 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
ppadat.c 205
3005 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
itmsrcpr.c 1328
3006 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
itmsrcpr.c 1145
-19
3007 E
Interne
100000 Interner
Fehler
2012-11-12 15:40:24
itmsrcpr.c 3942
-19 {args:
-19"}
3019 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
ppadat.c 205
3020 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
ppadat.c 205
3021 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
ppadat.c 205
3022 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
ppadat.c 205
3023 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
itmsrcpr.c 1328
3024 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
itmsrcpr.c 1145
-19
3025 E
Interne
100000 Interner
Fehler
2012-11-12 15:41:25
itmsrcpr.c 3942
-19 {args:
-19"}
[/QUOTE]
it seems you have run out of memory for Pickmaster queue handling.This could be caused by repeated triggers on an indexed work area without consuming the generated targets in rapid. The queue is filled up with new targets before the queue has been emptied. Doing this repeatedly may consume all available memory.Best regards,Anders0
