Setting up World Zones for IRC5
i_robot
Hi All,
I'm having a terrible time setting up world zones for two new IRC5 6600.
I have set up world zones before on M98 S4C's. I want to setup a sphere
around my home position and a box around the work pieces. I have used
the WZSphDef and WZDOSet commands for the home position to no avail.
Here is the actual code.
WZSphDefInside, shHome, Home.trans, nRadHome;
WZDOSetTemp, wzhomeInside, shHome, R1_Home, 1;
This code is in PROC wz_PowerOn() which is in user.sys.
I have attempted to set-up wz_PowerOn as an event routine that runs in
the background, but I don't know if I am being successful.
We are getting close to crunch time (naturally), and I am at the end of my rope.
Any help will be greatly appreciated.
i_robot2006-4-2 2:52:39
You probably forgotten one thing, I gess.
When you create a world zone, you need to connect the routine to an event, such as POWER ON, START...
You can make it in system parameters, SYS.cfg.
Here is an example..
* World Zone routine*
PROC rHomePos()
WZSphDefInside,shapeHome,pos1,50;
WZDOSetStat,wzHomeInside,shapeHome,do09_HomePos,1;
ENDPROC** SYS.CFG **
CAB_EXEC_HOOKS:-Routine "rHomePos" -Shelf "POWER_ON" -Task "T_ROB1"
Regards,
Thanks, but I had that right. My mistake was that in the wztemporary
and wzstationary datatypes I had the exact same zones names. This
generated an error upon start-up and completely threw me off.
