auto path failed??
Klaus
When i try to make an autopath from curve i get this error:
Auto Path Failed: Make sure the correct motion type (Linear or Circular) is selected in the active Instruction Template 21-11-2012 13:43:13 General
Where do i set motiontype in active instruction template
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
You can select the motion type from the status bar,
ABB0 -
Have the same problem. Could you please re submit the photo where I can find motion type option ?0
Found it. No need for a picture anymore.
- 38 AppStudio
