Serial Communication
Hi.
I have a problem with our IRB 4600 running RW5.12_04.00.4003.
For some reason the robot cant read strings from com1 unless I send 200+ characters over the channel. It doesn't seem to matter if I send CR+LF or EOF (Tried a bunch of different delimiters). However if I spam the robot with data it starts going through. Writing on the serial channel however seems to work just fine.
Settings:
Baudrate: 9600
Parity: None
Number of bits: 8
Number of stop bits: 1
Flow control: None
Duplex: Full
(Both PC and Robot have the same settings)
I get the feeling that it is buffering the data, but not returning it unless the buffer is full.
I'm using the following test procedure.
[CODE]    PROC SerialTestProc()
        VAR iodev comIn;
        VAR string sValue;
        Close comIn;
        Open "com1:", comInRead;
        ClearIOBuff comIn;
        WHILE TRUE DO
            sValue := ReadStr(comIn, Delim:="A"Time:=30);
            TPWrite sValue;
        ENDWHILE
        Close comIn;
    ENDPROC[/CODE]
Anyone got any ideas?
  • I am having this exact same problem.  Does anyone have a solution for it?
    It has been working great for a week and now it does not read anything until you type in 200+ characters.
