Error
What is wrong?
  • What operation did you do prior to the error?
    ABB
  • I got some new information from my developer colleagues: The fault is known and will not affect RobotStudio usage. You can continue using RobotStudio as normal. The error will be fixed in 5.15.01 (scheduled for April A'13)
    ABB
  • i have RobotStudio 5.15 64bit.
    It does not matter if I press oneClickConnekt or if I Create Empty Station to get that error message.
  • Thank you so much for your help.
