problem of s4filecopy? [WebWare SDK]
hello,
I want to copy one file from flashdisk to pc, so I use the instruction:
I_status = Helper1.S4FileCopy(Helper1.DevList(1) & "", Helper1.FileList(5), App.Path & "", Helper1.FileList(5), 3, l_ResultID)
devlist(1) is /hd0a/
filelist(5) is abb.prg
when I run this, it will always retrun -417 error( FTP Host File Error), the robot is s4c+,webware is 4.5 version.
connected bewteen robot and pc is ok, I can see the files in flashdisk by robotfilemanager.
someone can give me a advice? where I need to notice? thank you very much
alan
can you test this?
I_status = Helper1.S4FileCopy("home:", Helper1.FileList(5), App.Path , Helper1.FileList(5), 3, l_ResultID)
or
I_status = Helper1.S4FileCopy("home:","abb.prg", App.Path , "abb.prg",3, l_ResultID)
Bye.
Labwindows CVI user0 -
sir,
thank you ,I had tested use
I_status = Helper1.S4FileCopy("ram1disk:/../", Helper1.FileList(0), App.Path & "", Helper1.FileList(0), 3, l_result)
if I use the vitual controller, the status is 0 and copy will successful, but if I use the actual robot, status will return 3100 error
I don't know why
,give me more advice,thxalan
Helper.S4FileCopy has a small inconsistency between the Virtual Controller and the real Controller.
On the real controller you are not allowed to have a "/" in the "ToDev" parameter if it is a PC, instead if you want to browse down you need to have that in the "ToFile" parameter.
So if you want to write to the C disk you will have to have "c:" and not "c:/".Example you want to copy this "/hd0a/temp/ABB.prg" to here "c:/MyFolder/ABB.prg", then the command would look like this:
Dim intResult As Integer
Dim lngID As Long
intResult = Helper1.S4FileCopy("/hd0a/", "temp/ABB.prg", "c:", "MyFolder/ABB.prg", 3, lngID)John
Developer Center0 -
thx0
