Axis Limit increase
I tried to increase the Axis limit of 4th Axis in ABB safe robot from +  - 300 degrees to + - 315 degrees. It worked for the first time. Then I downloaded the safety controller to the controller and now the 4th axis does not go beyond its prest limit value, +- 300 degrees.
Anyone have any idea about it. PLease help
Nata
  • Hello,
    If I understand correctly, you did the following:
      -- Using the Configuration Editor, adjusted the limits of axis 4 using the Upper and Lower Joint Bounds, under the ARM parameter, (in radians)
      -- Setup a safety controller configuration and setup the Safe Axis Range (in degrees) usin g the Safe Move Configurator,
      -- Then when testing, you noticed that the axis 4 stopped (from the Safe Move stop?) at 300 degrees,
    Is that correct?
    Kind Regards,
       Steve
