Locate target - cannot select multiple targets
TomR
I am having trouble with RS 5.15 - in older versions when I right clicked on a path and selected locate target, it would locate all targets in the path - so I then could set position or rotate all the targets in that path. This doesn't seem to happen in the new version which is a problem for me as I need to rotate all the targets together and there are lots of targets in my paths.
This is a known problem that will be fixed in the next version of RobotStudio.
Henrik Berlin2012-12-13 14:35:43Henrik Berlin
ABB0
