Geometry import problem(s)
Hi!
I'm having a bit of a headace importing 3d models from our mechanic design team. See the detailed error description below. The only error I can find in the description is "Error : Translation aborted due to out of memory allocation problem" which appears a few times. Is this memory allocation problem hardware or software related?
Im running RS5.15 on win7(32bit) enterprise on a computer with specs that meet and go way beyond the minimum requirements for RS5.15
Thanks in advance, keep up the good work!
David
RobotStudio .NET exception: --------------------------------------------------------------------------------
Translator Name    : Spatial InterOp Connect ( Version : 23 0 0)
System Name        : Windows_NT
Machine Name       : M6600-6ZLKBT1
User Name          : KS04212
Source System      : Inventor
Destination System : ACIS
Input File         : C:Usersks04212DesktopBlstercell_080439_V2.ipt
Start Time         : Fri Dec 14 08:13:52 2012
Message : === Translation Options ===
Message : TranslateAttributes : true
Message : TranslateHiddenEntities : false
Message : Representation : BRep+Assembly
Message : Healing : true
Message : ===========================
-------------------------Source File Header Information-------------------------
Modification Date        : Wed Dec 12 10:03:16 2012
File Name                : "Utredning Pick N Place/ fixturer / Gripdon - Substitute"
Author                   : "JC"
Organization             : "CSM"
Version                  : 2012
Comment                  :
Units                    : MILLIMETER
Document Type            : Part
Source Document Preprocessing Result : Success
Target Document Preprocessing Result : Success
Start BRep
Target Document Postprocessing Result : Success
Target Document Postprocessing Result : No Entity to Translate
---------------------------Document Conversion Summary--------------------------
Finish Time : Fri Dec 14 08:13:53 2012
Translation Result : Aborted
Base exception: GeoException
User Name          : KS04212
Author                   : "JC"
Version                  : 2012
Comment                  :
Units                    : MILLIMETER
Start BRep
Server stack trace:
   at RobotStudio.Services.Geometry.ModelerService.Import(String bstrImportFileName, GeoPart pPart, CADFormat fmt, Boolean bTranslateHidden, Boolean bHealing, IProgressCallback pProgress, String bstrLogFile)
   at RobotStudio.API.Internal.AssemblyModeler.LoadPart(GraphicComponent parent, String fileName, DetailLevels lods, Boolean surfaceModel, Boolean translateHidden, Boolean healing, IProgressCallback progressCallback)
   at ABB.Robotics.RobotStudio.Stations.Part.Load(String fileName, IProgressCallback progressCallback, Boolean surfaceModel, Boolean translateHidden, Boolean healing, DetailLevels detail)
   at ABBInternal.StationLogic.ComponentServices.<>c__DisplayClass12.<<ImportComponents>b__e>d__15.MoveNext()
Exception rethrown at [0]:
   at ABBInternal.GUISupport.ProgressDialog.ShowWhile(Func`1 work)
   at ABBInternal.StationLogic.ComponentServices.ImportComponents(IEnumerable`1 fileNamesOrDocInfos, Boolean importGeometry, IHasGraphicComponents parent, Nullable`1 position, GeoImportOptions geoOptions)
