Rev. Counter Update Position
We have a robot that could not go to zero position in axis 2 because of the building structure. Is there any way to change the calibration position (about 40 degrees)?
Thanks for your help..
  • Hi
    Be aware of that you can calibrate axis by axis (no need to have all axis in zero just the one you select in rev counter update).
    Per Svensson
    Consat Engineering
  • Hi again,
    Thank you for your information but the real problem is I cannot move second axis to zero position because of the height no matter where the other axes are. So I think i need to change the rev. counter update position of the second axis.
  • @petorin
    I had this problem, move robot to home position then power down and restart doing the axis individually.
    This is on an ABB IRB0580
