TCP/IP communicating commands
Hello All,
Could you please give me suggestions. Is that possible to write a TCP comunicating program on the robot flexpendant ?
I have to start programming using the SocketCreate, SocketConnection or SocketBine instructions but I can't find the commands on the teachpendant; What should I do ?
Thank you inadvance, Jazz
  • Hi
    The instructions should be found under 'Add Instruction -> Communicate'. Note that you have to have PC Interface option installed in your IRC5 controller to have access to these instructions.
    -Osku
  • Thank you very much for your quick response.
    I will check the cost involved in the PC Interface update with the ABB.
    Thanks
