Modify instruction
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I just start to work with RS 5.15 and I have a problem when I want to modify a motion instruction in the station, after a load module on the VC and synchronisation to station. See error message. When I insert a motion instruction in a station path, modifying the instruction is not a problem. Can somebody help me?
Thanks in advance
VCG PAINT
Error message:
RobotStudio .NET exception: Object reference not set to an instance of an object.
Base exception: NullReferenceException
   at ABBInternal.ElementToolControls.InstructionHelper.AddInstructionArgumentToDynamicPropertyContainer(RsInstruction instruction, DynamicPropertyContainer dynamicPropertyContainer, RsTask task, RsInstructionDescription instructionDescription)
   at ABBInternal.ElementToolControls.EditInstructionHelper.InitializePropertyGrid(PropertyGrid propertyGrid, List`1 instructionList)
   at ABBInternal.ElementToolControls.EditInstructionHelper.WriteSelectedInstructionDataToPropertyGrid(PropertyGrid propertyGrid, List`1 selectedInstructions, List`1& templateList, Boolean& templateComboBoxEnabled, List`1& motionTypeList, Boolean& motionTypeComboBoxEnabled)
   at ABBInternal.ElementToolControls.EditInstructionTool.RefreshGrid()
   at ABBInternal.ToolWindow.ToolHostControl.ActivateControl(Type ctlType, CommandBarButton command, Boolean setFocus, Object[] selection)
  • Hi,
    If you attach a Pack&Go of your station, I can take a look at it.
    ABB Robotics
