Pack & Go and code behind
When you pack and go a project containing a custom smart component with code behind I found that it does not include the code behind dll. I have to manually copy this dll into the library folder created when you unpack the project for the smart component to work.
I had set the option to copy the library into the pack and go.
  • That is correct, code-behind in an external dll is not included in Pack & Go. You should embed the dll as an asset in the smart component.
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
