Profibus dp and IRC5
pacijent
Hello to all, could you please refer me to some manual that explains how to use profibus commands with IRC5, particularly command WR REC. How to use addresses in IRC5 for writing commands from PLC. Thanks.
You should read the application manual Profibus - DPYou should load HMS_1811.gsd file to the PLC. You can find them in your Robotstudio documents CD.There was Profibus DP Bus and Unit Type already installed in our system. What we do is to create a Unit and I/O signals defined to this unit.R&D Electronics Engineer0
