RAPID memory leak?
I think there is a RAPID memory leak with the following when the record being searched for does not exist.  Maybe someone can verify this and eventually fix?
RapidSymbolSearchProperties props = RapidSymbolSearchProperties.CreateDefaultForData(true);
props.LocalSymbols = false;
List<RapidSymbol> symbolsFound = new List<RapidSymbol>();
try
// This causes a leak in RAPID memory if the "myundefinedrecord" record isn't installed
symbolsFound.AddRange(this.Task.SearchRapidSymbol(props, "myundefinedrecord", ""));
catch
Controller.ReleaseUnmanagedResources();
return;
