BullsEye. TIG torch.
jesus
Hello.
I have a question about how to adjust the data be_scan (scan data) and data be_tooldesign (Tool Design) for TIG welding torch, for the calibration of BullsEye. The photo shows the gas nozzle and the tungsten electrode.
The electrode has a diameter of 2.4mm. The tip is sharpened at 22 degrees and the length of the sharpened tip is approximately 5 mm. The total length of the electrode out of the gas nozzle is 13mm.
Usually MIG torches that I use are simple in terms of setting BullsEye data, but it is the first time I set this type of torch.
Could I advise someone about this setting?.
Thanks in advance.
Jesus.
HiI think you should try to adjust the be_tooldesign data which is used in BESetupToolJ instruction. According to your tool dimensions you could try to use following values:MaxBodyDia 25MinBodyDia 12ScanRange 45WireDia 2.4Other components could be kept as their default values. Better description about these data components is found in the Application Manual - BullsEye.-Osku0
