Robot studio
HI I have a setup in Robot studio with robot and Wobj. here i need to move the base frame of the robot in X axis by 260mm +ve Direction. After moving the Base frame i need to configure the all the targets . before that shoud i need to reteach the Wobj ?
Am thinking that its matter of reachability because we are not going to move the co-ordinate value of the wobj.Kindly Revert your suggestions and ideas to me,,,,,,,
Regards,
Revathi D
revathi.
If you have a stationary workobject you can move the base frame and the work object independently of each other (unless you use wobj0 of course).
ABB0
- 40 AppStudio
