RAPID: Fetch Gravity_Beta value
I'm looking for a way to check the current Gravity_Beta setting and print it to the TeachPendant, using RAPID.
Is there something similar to GetSysInfo that works for Gravity_Beta?
John Wiberg2013-02-21 16:58:59
  • Would have been easier if you had said what type of object Gravity_Beta is.
    I looked it up and it looks like its a configuration, if so then you read it just like any other configuration file data:
    [code]Controller c = new Controller();
    ConfigurationDatabase cfg = c.Configuration;
    string data = cfg.Read("MOC", "ROBOT", "gravity_beta");[/code]
    Look in the file to get the exact location, the above is my guesstimate of where it should be.
    John Wiberg2013-02-19 11:58:53
  • John, I tried what you suggested. The compiler has all kinds of trouble with that code snippet. Will this work within a RAPID module? If so, what am I doing wrong? The robot system doesn't seem to recognize those commands/data types.
  • I have posten how to read cfgdata in rapid in this post http://forums.robotstudio.com/forum_posts.asp?TID=7773
    Maybe that will help you
    Per Svensson
    Consat Engineering
  • [QUOTE=Alyssa Wells]John, I tried what you suggested. The compiler has all kinds of trouble with that code snippet. Will this work within a RAPID module? If so, what am I doing wrong? The robot system doesn't seem to recognize those commands/data types.[/QUOTE]
    Ah.
    You have posted in the RobotStudio>Developer Center forum, in here we mainly talk about Application Development using the SDK's.
    So I assumed you were using the FlexPendant SDK. So the code is C# using the FlexPendant SDK.
    Per Svensson's suggestion to use ReadCfgData will fit you much better. For clarity I will post it here as well.
    [code]
    VAR bool bPathCollision;
    PROC CheckPathCollision()
    ReadCfgData "MOC/MOTION_SUP/rob1","path_col_detect_on",bPathCollision;
    TPWrite "Path Collision On: "Bool:=bPathCollision;
    IF bPathCollision=FALSE THEN
    WriteCfgData "MOC/MOTION_SUP/rob1","path_col_detect_on",TRUE;
    ENDIF
    ENDPROC[/code]
    For RAPID questions etc you should head over to the RobotWare forum.
    I've taken the liberty to edit the header of your topic to reflect this.
  • Thank you!
