Calculate Pose Value of the frame
Hi Guys,
How to calculate the pose values from the joint targets using RS-SDK?
The RAPID way is
pose pose1 := CalcRobT(jointtarget1, tool1 WObj:=wobj0);
Thank you.
Lingaa
  • sorry it is not pose it is robtarget
    robtarget tgt1 := CalcRobT(jointtarget1, tool1 WObj:=wobj0);
    Lingaa
  • Hi
    You can get the axis values from the joint taget using GetJointVal and then pass it into the
    ForwardKinematics method, which returns a 4x4 matrix, which you can set on a robtarget.
    Hope it helps,
    Regards Lars
    Lars Glud
    Danrob A/S
