Rot table with non-parallel axes
Trying to create a mechanism of a rotary table that has a smaller satellite rotary table on top of it. If I set the axis of both joints perfectly parallel to the world csys the mechanism creates without any trouble. If I set the axis for each joint as it is in actual machine, slightly off from perfectly parallel, Robot studio crashes when I try to compile the mechanism. This happens on RS 5.14.03 and 5.15.00.01. What exactly is the limitation here?
  • Hi Jeff,
    What you are trying to do should work. If you mail me (anders.spaak@se.abb.com) your geometries, I can take a look at it.
    ABB Robotics
  • Thanks Anders. I will send them on Monday when I return to work. I have narrowed the problem down to a situation where both axes in the mechanism are nearly parallel to each other, but not exactly, and are nearly parallel to one of the world axes, but not exactly. I can compile a mechanism where both axes in the mechanism are parallel to each other but slightly off from world without error. Luckily this is good enough for my application.
    Thanks,
    Jeff
