Set relative joint limits
I have a spray tool that has two hoses connected to it that are then mounted to the side of axis 4. I need to be very careful not to allow axis 6 or 4 to turn more than +- 90 out of sink with each other to prevent hose kinking. The two axes together can not turn more than +- 120.
Is it possible to set a joint limit relative to another joint? In my example I do not want to simply set limits for joint 6 at +- 90. I want to set +- 90 relative to the value of joint 4.
Thanks for any help.
-Jeff
In the motion parameters you can set a max for the rotation of each individual axis.on your teachpendant go to:ABB > configuration > topics - motion > arm > upper/lower joint bound.(not the independant)This value is in radians.so for 90 deg. this would be 1.5708/-1.5708If you fill this in for axis 4 and axis 6 it should work.RobWelding
The Netherlands0 -
The problem is that when axis 4 is at -60, for example, axis 6 can not be at + 60. This would be greater than 90 relative to each other. If axis 4 is at +30 than axis 6 can be at +60 without any trouble. So the limits aren't absolute, they are relative to the value of the related axis.0
The rotation of axis 6 is in fact always relative to axis 4.But the way I understand it now you would either need the option 'EPS' or 'Safemove'Because you want to be able to variate the limits.The other thing you could do is have axis 4 maxed at +- 90 deg and axis 6 at +-30 deg.RobWelding
The Netherlands0 -
If you let me know which robot you are using I can probably compile a custom mechanism that has a dependency between axis 4 and 6. The limitation will only be present in the RobotStudio mechanism itself (and not the controller).
ABB0 -
We are using an IRB2600-20-165. I appreciate the offer very much. If you can wait until tomorrow I can provide exact numbers for the limits. What I have posted so far has just been approximate.Thanks very much for the support.0 -
Hello,You can protect youre robot with a Worldzone in combination with a systempinput Stop.It a simple EPS option that you can make. When a axis combination is forbidden the robot stops his program. You still can jog the robot. But you can protect it for unwanted program positions.
See the documentation for more information.WZHomeJointDefInside,Rob_Stn_shape,jRobSafe,jRobDelta;
WZDOSetStat,wzRob_StnInside,Rob_Stn_shape,soSafePos_Rob,1;#
SYSSIG_IN:-Signal "siStn_Turn_Block" -Action "Stop"#
EIO_CROSS:-Lact "doACT_MU1 & *soSafePos_Stn & *soSafePos_Lenze" -Lres "siStn_Turn_Block"0 -
I have compiled a custom rslib with a dependency between axis 4 and 6. They may not deviate more that 90 degrees from each other. There is also an upper limit of 120 degrees for both the axes.
webwiz/772/IRB2600_12_165__01_DEP46_rslib_v2.zip
Here are the source files (.sat and .rsxml).The .rsxml script defines the mechanism. To compile it yourself, select "Import Library" and point out the .rsxml file.
What I have done (compared to the original version of the .rsxml file) is to add a mutual dependency between axes 4 and 6. This is defined by the points-attribute, see below. The points define a polygon in the J4/J6 plane that specifies the allowed joint values.
To use the custom rslib, just open "Edit System" and exchange the original rslib.
Henrik Berlin2013-03-11 20:17:25Henrik Berlin
ABB0 -
Thank you very much for this Henrik. I'll give it a try today.0
- 38 AppStudio
