"Disp.xml" Import
I met a problem when I import the "Disp.xml" through the "Instruction Template Manager".
The robot is IRB4400/10L. It is always invalid. I don't know why.
But in a empty station, I can import this "Disp.xml" successfully.
Here is a pic to show the error. Seems some problem with the "Bead1'?
  • Hi,
    It is the validation that not is correct, the templates will work even if you get the message that they are not valid.
    But on your Picture I can see that you have mutiple "Move Instruction Descriptions" for the dispense instructions, which not is a good idea.
    ABB Robotics
