quick question : How you deactivate a robotstudio sensor?
Maraiica
i wanted to activate and deactivate the sensor..? There are "active" in the i/o connection in targeted object and signal..but there are no deactivated..how do i do this??
For SmartComponents (SC) that have the Active signal it is an input. When it is High (1) the SC is active, i.e. responding to input, and when it is Low (0) the SC is passive, i.e. deactivated.
ABB1 -
THANKS..There is another problem after that..i activate the sensor and the line of item will stop..after i deactivate the sensor..the line of items will move again..but..only the last item will move..the first, second and third item still at the same spot..why is that??and what can i do??please advise..0
It is hard to answer without known more about what you are trying to achieve, and what your setup looks like. If you upload an .rspag of your station it would be easier to provide an answer.
ABB1 -
I cant seem to attach the file to you..can i have your email, so i can email it to you.
Im having problem with files attachment too.
