SmartComponent Information
PerSvensson
I have made a smartcomponent with code behind but I have an issue which could be hard to explain but I will try to give an example what I basically want to achive.
The smart component has lets say 2 properties
- Mechanism (RobotStudio mechanism)
- Path (string)
Then I load two instances of the smartcomponent library into RS.Lets say I name them SC_A and SC_B
But before starting the simulation I need to figure out which mechanism that is defined in SC_A and SC_B because I has to do some pre setup.
When you start the simulation you get this information in the component parameter of SimulationStart but this is to late.
- Path (string)
Per Svensson
Consat Engineering
Consat Engineering
Found a way to do itPer Svensson
Consat Engineering0 -
Hi Per, I think we had a mail thread on this topic and that I possibly gave you some ideas. Or I didnt B-) Dont remebmer now.Anyway, could you share with us, how you solved it?0
