TpsLabel error
I'm doing my first project using Screenmaker and I've run into a problem. I'm trying to use a tpsLabel but whenever I try to open the screen that contains this control I get an exception, see attached picture.
Is it something I've done wrong or is this a bug?
  • Hi luetin,
    this seems like a problem with backwards compatibility between the properties available on the TpsLabel when you build your screen in ScreenMaker, and the properties available on the TpsLabel on the FlexPendant where your screen is executing.
    This is something that should not happen. Can you please tell me:
    * which version of RobotStudio did you use to create your screen
    * which version of FlexPendant SDK did you select when you launched ScreenMaker? (I.e which version of RobotWare are you targeting)
    * on which version of RobotWare do you run the screen?
    Thanks.
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
